can i use 410 diffs in my sammy axles
- turbo-tom
Re: can i use 410 diffs in my sammy axles
the harder you try the more things get broken it all depends how much right foot you give it!
He said low so I went low.
2 front diffs anyway. What you take them from depends on the rest of your ratios and what you use the truck for
i go doin stupid things it get sum shit i got offers sum 410 diffs cheep but they wont go in will they so i need keep lookin
Do you need to drive it on the road? If so you need to consider whether replacement diffs will reduce your top road speed too much.
410 Diffs only fit in 410 axle casing (as casing/diff housing is smaller!)
413/Samurai/Vitara FRONT Diff's can all be swapped around, do note that a rear vitara diff won't fit a 413/Samurai Diff housing.
413 axles can usually be picked up cheap, as they're not as sought after as the samurai axles (wider axle/stance/more stability).
Try Mike Harris on here, he often breaks Sj's & has a very good reputation with good second hand parts!
