The throttle pedal isn't fully depressed is it?
If not you could attempt to very carefully trim a bit of the outer off with a Dremmel or die grinder to shorten the outer.
Throttle cable n
- Ladaman
- Suzuki Guru
Re: Throttle cable n
Al av done mate is got the cable n hooked it round the throttle on the engine and thats where it sits but if a would go to put my foot on the pedal it wouldnt move so think cabel is to short
Change the inner cable. I'm using a bike rear break cable been in 3 years no problems
Thanks robbie will try something , lyk that did u use the hole bike cabel
Had to file the nipple a bit to fit the pedal end then pushed it through the outer cable. I used a screw on nipple on the cab end and trimmed to length
Thanks robbie think a could manage knock sumit up lyk that thanks
