- SCUK is my life
Post
by andyrew » Fri Aug 30, 2013 5:19 pm
Hey guys
Not sorted yet.
If im not having a curry with my good lady tonight im up the barn.
Updates Saturday if I get them working Or find
the fault
Or check the breaking section sunday
Hey rick
If you don't mind salvaging the servo and master of scooby
They would be handy for spares. The replacement one at the moment
May have a little weep from the reservoir. Hoses may be handy too.
Cheers dudes
4x4rick
Post
by 4x4rick » Fri Aug 30, 2013 6:39 pm
Jordi wrote:4x4rick wrote:andyrew wrote:Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
Swapped hoses over tried old rubber hose too
Swapped calipers over both okay
Bled with calipers up top
Fitted another master and servo ( cheers jordi)
Clamped off rear feed flexi hose from wing to chassis front brakes working fine good solid pedal
Blanked off one side of axle t piece . Drivers rear good solid pedal
Blank other side of t piece and Try with Rear passenger and it just lets pedal to the floor
So im left with the t peice or copper pipe being at fault which makes no sense.
will try again tomorrow. Im heading home
Andy... I have braided hoses across the rear axle a good t/pipe
will bring along with me also got the servo if u fancy swapping stuff around to eliminate the one fitted
He's on the second servo and master cylinder now.
I know jordi... just thought they might help him out a little
after his done/doing so much running about for everyone/me
karma
Rhinoman
- Suzuki Guru
Post
by Rhinoman » Mon Sep 02, 2013 9:19 am
Does the handbrake work? are the rear shoes actually adjusting up? I have an issue with mine at the moment having replaced the shoes on the back and the handbrake doesn't work even though the lever only comes up four clicks. I need to extract it from the flower bed and take another look at it
4x4rick
Post
by 4x4rick » Tue Sep 03, 2013 7:55 pm
parts are at mine Andy (london)
im at m25j22 mcdonalds on the 5th from 7.30
vw t4 meet
- SCUK is my life
Post
by mike harris » Tue Sep 03, 2013 8:32 pm
Still got issues mate?
- SCUK is my life
Post
by mike harris » Tue Sep 03, 2013 8:34 pm
Do you find you have to pump the pedal for the rear brakes to work?
As a sj master cylinder is not man enought to power all round discs, in my opinion
Maybe try a bigger master cylinder? Subaru impreza or v6 vitara?
Post
by turbo-tom » Tue Sep 03, 2013 9:37 pm
i think the sj servo is fine on discs all around, each to there own i guess
suzukisteve
- Suzuki Guru
Post
by suzukisteve » Tue Sep 03, 2013 9:40 pm
sorted???
pickle power!
- SCUK is my life
Post
by andyrew » Tue Sep 03, 2013 9:42 pm
YEAAAHHHHH ROYYYYYYYY!
Tso with New fittings. T peice and pipes it was better but still able to just go
To the floor. New hoses the lot. New pads and discs
Still had the issue. Had the calipers clamped to blocks of wood with the nipple at
12. One was still causing a soft pedal.
What was the problem? ?????
Its was the flipping wood. It was soft as it was soaked in fluid so it just compressed.
Im such a bell end .
- SCUK is my life
Post
by andyrew » Tue Sep 03, 2013 9:44 pm
4x4rick wrote:parts are at mine Andy (london)
vw t4 meet
Awsome. Might even pop up in the lwb!
