Engine out
Re: Engine out
Post by ScottieJ » Sat Aug 10, 2013 7:22 pm
Personally I prefer the use of an adapter plate as you aren't left with big gaps to let mud into the bellhousing. yeah mud finds its way in anyway but nowhere near as easily if you run the plate, we used one on my dads conversion and I have one sat in the workshop already for when I go 1.6 with the Lwb.
Even with the conversion plate you still need to drill out the top two holes to 12mm though.
lukey4x4
Re: Engine out
Post by lukey4x4 » Sat Aug 10, 2013 7:47 pm
thanks scottie think I mite just have to buy one sounds easier, whers best place to get one from ebay £50 ?
Re: Engine out
Post by turbo-tom » Sat Aug 10, 2013 7:50 pm
they come up forsale every now and then.
lukey4x4
Re: Engine out
Post by lukey4x4 » Sat Aug 10, 2013 7:55 pm
thanks aye al just have to keep an eye out
lukey4x4
Re: Engine out
Post by lukey4x4 » Sat Aug 10, 2013 8:11 pm
quick question when using the conversion plate do u still use the metal gasket off the gearbox or not
Re: Engine out
Post by Jordi » Sat Aug 10, 2013 8:27 pm
I just used the adaptor plate. Not sure if its different depending on which adaptor plate you use. There is a couple of different ones kicking about.
lukey4x4
Re: Engine out
Post by lukey4x4 » Sat Aug 10, 2013 8:41 pm
orighty think al just buy the one off ebay only 1 a can find cheers
Re: Engine out
Post by ScottieJ » Sat Aug 10, 2013 10:22 pm
Take out the thin metal plate when using an adapter plate :thumbup:
lukey4x4
Re: Engine out
Post by lukey4x4 » Sun Aug 11, 2013 12:04 am
Thanks scottie
Re: Engine out
Post by turbo-tom » Thu Aug 15, 2013 5:46 pm
There is one on the facebook page if your still after one mate.
