vitara pas pulley set up,help needed!
- turbo-tom
Re: vitara pas pulley set up,help needed!
or just run one belt like i keep a spare in the back
So you have one belt running everything including the pas pump? Do you have a pic handy of the setup? Cheers
Ok cheers! and what did you do about the pulley on the pas pump? got any details on the belt at all?
- turbo-tom
i left the stock pulley on the pas pump, but i have however moved my pump slightly higher up then standard. I will have to look to get the belt length/type tomorrow when im in the garage. i know its multi v belt,to be honest fella i put all the belt tensioners like the alternator and this case the pas pump roughly in the middle then got a piece of cable put it round all the pulleys then went to my local motor factors and said i need a belt this long etc and they got me one...
sorry its not the best picture but im afraid i cant get to my suzuki at the present moment.
That looks good mate thanks! Only problem is I've realised I can't get a multi v pulley to fit my lower crank so would need to change the pas pump pulley to suit the old ones and get a single v belt to fit round them all unless I get a multi v welded to my old crank pulley then use 2 different types of belts
- turbo-tom
No worries. Yeah you can change the pulleys around/find ones that fit, you got any pictures of your curent set up ?
Everything is just standard at the moment mate! found this though which i think i might do the trick.....http://www.wazuks.com/forum/viewtopic.php?t=1014
- turbo-tom
hmm can't find much about 410 with pas you thought about running a electric pump like Justaddmud has?
http://forum.suzukiclubuk.co.uk/vi ... 5&start=60
Did think about it but as ive already bought everything from a vitara im just gonna try and if i get it all working ill do a write up with plenty of pics as ive not seen any for sj410s with the f10a engine so hopefully help others?
