Page 2 of 2
Re: Smokey Engine
Posted: Tue Jun 18, 2013 8:16 pm
by Gardiner
Ok I shall find another gauge Im sure work has one.
I checked 1 plug at a time with other 3 in is that wrong ????
Re: Smokey Engine
Posted: Tue Jun 18, 2013 11:40 pm
by Ladaman
It should be all plugs out and throttle open. The cranking speed is higher then.
I'm afraid it won't make yours much higher though.
I'm going for slack valve guides, causing poor markings when lapping. (Unless your gauge is shot).
Re: Smokey Engine
Posted: Sat Jun 22, 2013 10:28 am
by Gardiner
Ok so I have done as per instruction as its pretty much the same so highest I got is 30 psi so I must have a major problem :cry:
Re: Smokey Engine
Posted: Sat Jun 22, 2013 12:53 pm
by Ladaman
If you squirt oil into the bores and the pressure goes up, that indicates worn bores and rings. If it stays the same, it's usually the head. Probably the valves.
Looks like you might need to do them again. :cry:
Re: Smokey Engine
Posted: Sat Jun 22, 2013 6:25 pm
by Rhinoman
Are you sure that you have the valve timing correct?
