Page 2 of 2
Re: SJ 410 tin top rear seat belts
Posted: Thu Jun 06, 2013 6:42 am
by windsor
No problem hope these help if u need any more just ask
Posted: Thu Jun 06, 2013 6:43 am
by windsor
Allso mine is a import so could be the reson
Posted: Thu Jun 06, 2013 8:37 am
by SteveR
Thanks again Windsor. Going by your pic just what the doctor ordered.
that mounting point or rear wheel arch, I have not got one, any chance of photo under the carpet. Guess there must be some sort of plate inside and one under wheel arch. Could you have a look to see how done as that point is not normally ideal for a seatbelt mount point. Do you recon it is original suzuki work ?.
thanks
Steve
Posted: Thu Jun 06, 2013 8:39 am
by SteveR
Sorry to go on but go to get this right as it is for my little kids so no mistakes allowed.
Steve
Posted: Thu Jun 06, 2013 11:54 am
by windsor
Dont worry about it steve ill have a look for you
Posted: Thu Jun 06, 2013 7:03 pm
by windsor
Bolted throgh the arches
Posted: Thu Jun 06, 2013 9:06 pm
by dan_2k_uk
Well I never. Must be a rare option!
Posted: Fri Jun 07, 2013 7:35 pm
by penpontgreenwoodwork
Put a pair of SJ front 3 point inertia belts in the back of mine yesterday. Spool half way up, pivot above that (as in pictures above). End of belt fitted to prethreaded hole about 2" away from rear body mount. Mine had had a plate welded in the rear corner covering the hole but the captive nut could be seen from beneath so I could measure where to drill through the plate from above. I'd guess all SJ's must have these holes, they're inline with the belt socket mounting holes in the centre. Hope this is helpful.
Posted: Sun Jun 09, 2013 12:20 pm
by SteveR
thanks for the input guys.
Now I understand how to do just got to find some good used belts of right length.
Will be putting inertia types in using the already there four bolt holes along rear of floor by door and 3 on each rear side panels.
will be at least a couple of months as away but when I get it done will post pics.
Steve
