Page 2 of 2
Re: Part numbers required
Posted: Mon May 20, 2013 1:45 pm
L970 AKM
The reg of my old 8V vitara that was scrapped a long time ago
I use Goodyear gatorback 4pk0813g belts for both alternator and P/S pump providing you are using an original mount and pulleys
Posted: Mon May 20, 2013 2:19 pm
by ROBBIE
ScottieJ wrote:L970 AKM
I tried that had the reg of the vit my old engine only to be told it came back as scrapped, so they couldn't get any info for it
Posted: Mon May 20, 2013 3:03 pm
I've never had a problem using it, it's what I always use, should still come up with the correct vehicle even if it is scrapped.
Posted: Mon May 20, 2013 3:11 pm
by turbo-tom
I just do what twiss does just get a reg of ebay works first time for me!
Posted: Mon May 20, 2013 3:14 pm
by suzukisteve
yeah as scottie said 4pk813
Posted: Mon May 20, 2013 3:59 pm
Is that with the PS pump in the original place scott?
Not lifted up?
Posted: Mon May 20, 2013 4:21 pm
Jordi wrote:Is that with the PS pump in the original place scott?
Not lifted up?
Yeah that's with it in the original place, means I only have to carry one spare belt if they are both the same, not sure if it would be long enough to use with it lifted? Might do depending how much you lift it though?
Posted: Mon May 20, 2013 6:03 pm
Sound.
Thanks lads. I'll give them another ring tomorrow.
Posted: Mon May 20, 2013 6:36 pm
by trotter
if scots reg doesnt work try M149 AEU thats the one dans engine came out of and we both use it with no problems even though its listed as scrapped
Posted: Mon May 20, 2013 7:05 pm
by penpontgreenwoodwork
I worked for a factors till a few years ago, belts only need the rib count and spec (air con, PAS etc) if ever in doubt about parts, look at all the options then give back the ones with the grubbiest boxes! They've been returned that many times
