Page 2 of 2
Re: Prop spacer needed
Posted: Mon May 20, 2013 2:58 pm
Oh yes I was going to take some pics of my ruined upside down rear springs!!!
They are absolutely trashed and a perfect example of why all extended shackles need to go in the bin!
Posted: Mon May 20, 2013 3:14 pm
by turbo-tom
ROBBIE wrote:turbo-tom wrote:Shackles aka fangs.
aka spring killers
AKa bollocks.
Posted: Mon May 20, 2013 4:59 pm
Longer shackles aren't spring killers if set up correctly and the shackles aren't too long
Also if you run a samurai with the smaller diff flanges then a late 410 propshaft is a better and probably cheaper alternative to a prop spacer, they are around 1" longer than samurai props
Posted: Mon May 20, 2013 6:48 pm
by ROBBIE
3 inch over standard = spring killer as I found out with the ones that came with the SJ
Posted: Mon May 20, 2013 6:52 pm
ROBBIE wrote:3 inch over standard = spring killer as I found out with the ones that came with the SJ
That much over standard and it'll max out the shocks
it's like the ones that were fitted to karis's when we bought it, the previous owner must've forced the springs down to get the shackle bolts in, the were S shaped where the shocks had no down travel left
