1600 PAS pump - moving it
Re: 1600 PAS pump - moving it
Post by dan_2k_uk » Fri Apr 19, 2013 3:07 pm
My vit rad is on the 1.3 brackets thats why I did the PS mod.
Post by ROBBIE » Fri Apr 19, 2013 3:50 pm
So what about the pulleys? I got a v belt pulley can I just weld the flat belt one to it?
Post by ScottieJ » Fri Apr 19, 2013 4:09 pm
I would swap your alt pulley over to a multi V belt and run a vit double pulley so that you run multiV belts on both, saves messing about with a cut and shut pulley that might end up out of balance or not true.
Post by ROBBIE » Fri Apr 19, 2013 4:15 pm
ScottieJ wrote:I would swap your alt pulley over to a multi V belt and run a vit double pulley so that you run multiV belts on both, saves messing about with a cut and shut pulley that might end up out of balance or not true.
Any one got one?
Post by Jordi » Fri Apr 19, 2013 8:07 pm
Got a jimny bottom pulley
Post by ROBBIE » Fri Apr 19, 2013 8:30 pm
Jordi wrote:Got a jimny bottom pulley
Sounds good how much??
Post by Jordi » Sat May 25, 2013 10:26 pm
Just re read this and it says it needs moving to clear standard rad mounts.
As i'm fitting a vit rad on custom mounts presume i can leave the pump where it is?
Post by dan_2k_uk » Sun May 26, 2013 12:26 am
If you cut the mounting tab on the chassis a bit. Or you could extend the slider and collapse the bracket and try the pump in the standard position which I think Ferris runs. Shorter belt I think.
