Page 2 of 3
Re: Which locker?
Posted: Wed Feb 20, 2013 7:49 am
Re: Which locker?
Posted: Wed Feb 20, 2013 8:36 am
by Richie
Lol u guys have a answer to everything.
Mainly use the suzuki 1-3 times a month for green laning or pay to play sites, but i do drive to them (normally 10-60 miles each way)
Cant really spend £1200 for a couple of arb lockers, thats silly money on a toy. But there must be a happy medium for about 50p? lol
What about this, I weld up both front and rear diff then get free wheeling hubs and lock every wheel when i get to the pay to play sites?
Re: Which locker?
Posted: Wed Feb 20, 2013 8:52 am
Ah if you aren't using it on road that much then go for a lockrite
I use mine on pretty much a daily basis so would probably get bored of the handling characteristics of one.
You can get the chinese air lockers for about £800 for a full set including the compressor though
Re: Which locker?
Posted: Wed Feb 20, 2013 6:35 pm
by Richie
Ok lockrite sounds the way foward, front and rear both worth doing?
Btw u didnt give ur feed back on this
Re: Which locker?
Posted: Wed Feb 20, 2013 9:41 pm
by mike harris
Just go lock rites, trust me
Re: Which locker?
Posted: Wed Feb 20, 2013 10:32 pm
by Richie
Mike u said u have them front and rear? have u had any probs with them and do u drive ur sj onroad?
Re: Which locker?
Posted: Wed Feb 20, 2013 11:01 pm
by mike harris
Yeh front and rear.
No I don't use it on the road, but doing as little image as you do I can't see a problem in using them.
There awesome, and if they are setup properly you won't have any issues with them.
Mike
Re: Which locker?
Posted: Thu Feb 21, 2013 9:29 am
by dan_2k_uk
Your FWH idea will only work if you drive there in 1wd and I'm not even sure you could fit them to the rear.
Could weld your front diff and run front FWH and have a permanantly locked front diff when you get there. Not good for steering though.
Probably not the best idea.
If you are using the truck on road and can't afford the ARB either fit an unlocker like the lockrite or find something else to spend the money on.
Re: Which locker?
Posted: Thu Feb 21, 2013 1:01 pm
by Anton
dan_2k_uk wrote:If you are using the truck on road and can't afford the ARB either fit an unlocker like the lockrite or find something else to spend the money on.
Like fiddle brakes?
Re: Which locker?
Posted: Thu Feb 21, 2013 1:04 pm
by dan_2k_uk
Not legal but if you're friendly with your MOT tester......
