Page 2 of 2
Re: Bad vibes ?
Posted: Sun Feb 17, 2013 9:20 pm
by dunnin21
Yeh I think I'm with you. So if I lined them up so the bolts are in same place. Ill do this as there not lined up at the min. I didn't relise this would affect it ill line them up and go from there
Re: Bad vibes ?
Posted: Sun Feb 17, 2013 9:32 pm
If you pull the shaft apart there should be marks to match up, obviously you only need to unbolt one end to move the shaft into the right position
- image.jpg (2.58 MiB) Viewed 2358 times
In phase means that the yokes are lined up correctly, like in this pic.
- image.jpg (2.45 MiB) Viewed 2358 times
