Page 2 of 3
Re: i need new springs
Posted: Thu Jan 10, 2013 9:30 pm
£495 for +1.5" springs from lama. Running rough country front shocks cant remember how much. Saw the second hand ones on here for £120 a pair. And KYB on the rear £70.
Extended braided hoses from llama again, id have to check price.
Posted: Thu Jan 10, 2013 9:57 pm
£34ea for my front shocks. Fulls set of braided hoses at +3" inc. the two from master cylinder in the wing were 84.65.
Posted: Thu Jan 10, 2013 10:26 pm
The monroe shocks will be astra shocks.
Posted: Fri Jan 11, 2013 8:58 pm
by dazerede
just looked on west coast offroad which sells ironman springs and it says these springs are suitable for
Suitable for:
TOYOTA HILUX LN 65,67,105,106 MK3 11/1983 – 11/1997
TOYOTA LANDCRUISER 40 SERIES
TOYOTA LANDCRUISER 60 SERIES
TOYOTA LANDCRUISER 70 SERIES (LEAF SPRING)
NISSAN PATROL MK G160 1984 – 1988
SUSUKI SJ 1981 ON
is that right here is the link
http://westcoastoffroad.co.uk/ll-kits/
think i shall do some research before i can afford some
Posted: Sat Jan 12, 2013 4:32 pm
by dazerede
My height of my sj is 17 inches from floor to bottom if sill with a set if 27 inch tyres is that good can any of u see what's the height from floor to bottom of sill on ur sj
Posted: Sat Jan 12, 2013 4:57 pm
by Jay18
i got my standard springs from jap4x4spares, i think ive spent about £350 on the full set of standard springs..
if i was you id do the rascal rear spring swap, ive priced up all lifts and worked out that one to be best price for a good safe lift..
you'd need:
SJ rear springs..
remove flat leaf and add one of the leafs from the old front leaf set..
rascal rear springs..
rascal rear springs and if you have the money some missing link shackles, but for cheaper way to do it extended shackles front and rear
extended hoses
extended shocks (you already have them right?)
and if i was you a new set of U bolts...
you may need 4 M12 bolts about 100mm long as the fixed end of the old springs can be a barsterd to get off and you may need to break out the grinder with a cutting disc and chop the old bolts and replace them...
Posted: Sat Jan 12, 2013 5:05 pm
by dazerede
I was thinking of doing that but heard that ironman springs was about 250 quid a set but I shall call west coast 4x4 just to see how much they are
Posted: Sat Jan 12, 2013 5:10 pm
by Jay18
yer shop around and see what you can get..
keep us updated and if you do get round to lifting it, make sure you put it in you thread
Posted: Sat Jan 12, 2013 5:34 pm
Just measured mine and i've got 21" bottom of sill to floor.
Posted: Sat Jan 12, 2013 5:38 pm
by dazerede
What tyres have u got I've got
27 inch and 17 inches to bottom of sill
