Re: Front axle issue in 4wd
Posted: Tue Sep 04, 2012 9:47 pm
Thanks for the info I will check the bearings beforehand
I do know there is play in that wheel so could be wheel bearing anyway. Hopefully will do with new grease and adjustment instead of replacing but I don't mind replacing things just for piece of mind anyway.
What kind of movement will I notice if the kingpin is worn?
