Re: Vitara trailing arm mod...
Posted: Thu Mar 29, 2012 8:31 pm
You're absolutely right, and I will make completely custom arms at a later date - the vitara arms are being used because they're cheap and easily available, plus they're standard Suzuki parts - so come inspection time, the man from VOSA will probably be more inclined to accept them.twiss wrote:If you're fabbing it up then there's no point in using vitara trailing arms.
You could pick something with stronger arms, ones that are easier to fit rose joints onto
Again, you're probably right, but for now I think I'm going to use the standard vitara A-Arm, just until the man from VOSA signs me off. I don't like the thing, but I'm sure I can make it work, and then make something more permanant later. I don't think I'll use a rose joint though, they tend to wear fast if you dip them in mud a lot, I'll probably use a johnny joint.twiss wrote:Also for the middle link I reckon that mount wont be very suitable.
An "A" section mounted with regular bushes onto the axle and a rose joint attaching to the new crossmember would be better
4 link is nice, but a good 3 link should give me more than enough articulation. I do *want* triangulated 4-link, but again - the man from VOSA...twiss wrote:The question needs to be asked though, if you're going to all the effort why not go 4 link.
It will be much better than 3 link, and if you're fabbing it up yourself it seems like a waste of time to take it all off, fab up 3 link, then stick it all back on again.
Might as well get it bang on first time as its a substantial mod!
Not according to VOSA. As long as I don't modify the chassis, the vehicle just needs a quick inspection down at my local VOSA office, not a full IVA test (which is now so stringent, most of the cars made by the big manufacturers 5+ years ago would have failed today's IVA test when new!). Having said that, VOSA's rules are a bit like voodoo - even VOSA don't understand VOSA's rules.twiss wrote:You should also remember that if you coil convert it you will need to SVA test it to use it legally on the road
Which is why I'm planning on making this in such a way that I can switch back to leaf springs if I need to - that is, use the leaf spring mounts for trailing arms, keep the leaf spring perches, and make the coil perches around/with/in the leaf perches.
If I make the coil suspension as "Suzuki" as possible, it's more likely to satisfy VOSA - if they moan, I'll switch back to leafs and ask them to inspect it again. The A-Arm then just becomes an anti-wrap bar. I don't want to IVA test the car, that's nearly impossible to pass these days, and costs an arm and a leg.
