Brake Pipes
Re: Brake Pipes
Post by turbo-tom » Fri Mar 02, 2012 11:34 pm
correct me if im wrong but i think its:
Passenger side rear
Driver side rear
Passenger side front
Driver side front
ianedwards
Re: Brake Pipes
Post by ianedwards » Sat Mar 03, 2012 4:09 pm
yea sure is, but i think the only really applies to abs,
i could be wrong tho.
Ian
Ian. :)
Re: Brake Pipes
Post by ROBBIE » Sat Mar 03, 2012 6:00 pm
i was taught to do it start furthest away form reservoir
Re: Brake Pipes
Post by turbo-tom » Sat Mar 03, 2012 6:08 pm
ROBBIE wrote:i was taught to do it start furthest away form reservoir
that order is i think :lol:
ianedwards
Re: Brake Pipes
Post by ianedwards » Sat Mar 03, 2012 9:01 pm
hi, just asked my mate, who's a garage fitter, he said it should be, or the way they do it.
offside rear > nearside rear > offside front > nearside front,
Ian
Ian. :)
Highlander
Re: Brake Pipes
Post by Highlander » Sat Mar 03, 2012 9:39 pm
I do it the way Tom said, both rears first.
Ian, most cars now have a separate brake line for each wheel due to ABS/Traction control etc so if you are only removing air it won't matter what order they are done in.
If you are completely replacing all the fluid then you will need to follow the manufacturers recomendation as to sequence.
previous to that they used two separate diagonally opposite systems,
so front O/S and rear N/S operate off the one brake line
Front N/S and rear O/S work off another
So that if one line fails you still have one front and one rear brake operating, rather than either front or rears.
Our Suzuki's are real old!! :D
Re: Brake Pipes
Post by ROBBIE » Mon Mar 05, 2012 12:18 pm
the reason i said about starting furthest away from reservoir is i done a fiesta the other day and it and the servo were on the passenger side :screwy:
Re: Brake Pipes
Post by twiss » Mon Mar 05, 2012 1:47 pm
Yeah you should start at the furthest from the reservoir, which is indeed passenger side rear on a RHD SJ
