Page 2 of 3
Re: Benefits of having a second battery?
Posted: Wed Jan 04, 2012 9:36 pm
by Tramp
That's clever but I'm sure you could rig up something as good (but maybe not as pretty) for a lot less, personally I'd use a voltage gauge accross each battery and a contactor fed from an ignition live & a self maintaining circuit, that way it would seperate the batteries when the ignition was off & you would have more manual control
Posted: Thu Jan 05, 2012 11:11 am
by Highlander
But..... in the situation when battery 1 goes flat wouldn't that mean you couldn't use battery 2 to start the car since the contactor switch wouldnt activate as you have no power to the ignition?
There are a lot of these fancy switch gear setups but the prices are horrendous and to my thinking the more complicated you get the more there is to break
I looked into it quite extensively at the time and decided the £5 manual switch suited me!
Its actually fairly easy to get used to.. connect the two batteries whilst engine is running, disconnect them when its stopped, doesnt need to be done every time, just so long as battery 2 gets a good charge
gauges are a good idea though, would be good to see everythings ok with the batteries
Posted: Thu Jan 05, 2012 12:38 pm
by Tramp
Good point I was thinking more of a situation where you would run the 2nd battery flat (when winching etc) ok maybe it would be more difficult but I'm sure it would be possible, I might even draw up a circuit!
Posted: Thu Jan 05, 2012 1:59 pm
by Highlander
Sounds good, see what you can come up with..
I don't mind the manual switch I have but some sort of automated thing that would take me out of the system would be ideal.
The way it is at the moment I am the weak link in the system, if I fail to turn on the switch and charge battery 2 or forget to turn it off and flatten both of them.
To be fair I've never flattened both batteries winching out a Suzuki yet
![:D :D](./images/smilies/icon_biggrin.gif)
Posted: Fri Jan 06, 2012 3:17 pm
by Tramp
What about something linked to the hand brake, as soon as its taken off the batteries are linked with a push button on the dash to override this limit (so you can start with a flat primary) & possibly another latch switch so you can stop the batteries connecting together
Posted: Fri Jan 06, 2012 3:56 pm
Surely having a split charge on a relay is the best and simplest way to have it automated, just want a manual override so you can isolate them when needed.
Posted: Fri Jan 06, 2012 4:01 pm
by Highlander
Tramp wrote:What about something linked to the hand brake, as soon as its taken off the batteries are linked with a push button on the dash to override this limit (so you can start with a flat primary) & possibly another latch switch so you can stop the batteries connecting together
Thats a great idea!
just like another handbrake switch running to a relay thingy?
Posted: Fri Jan 06, 2012 4:06 pm
by Highlander
ScottieJ wrote:Surely having a split charge on a relay is the best and simplest way to have it automated, just want a manual override so you can isolate them when needed.
it is but its not the cheapest way to do it.
I didn't pay £200 for my Suzuki, so I'm not paying £200 to connect the batteries together!
I reckon tramp's onto something there that I could probably rig up using bits from a car
Posted: Fri Jan 06, 2012 4:16 pm
£200
the X-eng set up is only £40
or you can make your own
http://www.rawcomponents.co.uk/100-amp-12v-relay.html" onclick="window.open(this.href);return false;
http://www.rawcomponents.co.uk/200-amp-12v-relay.html" onclick="window.open(this.href);return false;
Posted: Fri Jan 06, 2012 4:30 pm
by Highlander
Yeah it was this one that was £200+ nice bit of kit though.
That relay you linked to is what Tramp's talking about I think, with a switch on the handbrake providing the feed to switch it on
