Page 2 of 2
Re: No brakes
Posted: Thu Jan 19, 2012 6:08 pm
by Smalljeep
my cousin took a look at the brake calliper with the new bleed valve, and when tightening it up managed to snap it
Re: No brakes
Posted: Tue Jan 31, 2012 9:24 am
been there, done that, bought the t-shirt
Re: No brakes
Posted: Tue Jan 31, 2012 5:05 pm
by dan_2k_uk
My rears have no bleed nipples.
Ive bled then twice using the hose connection without a problem.
Take the caliper off and.fill it up with.fluid on its side.
Hold your index finger and thumb over the ring on the end of the hose and have someone pump the pedal.
Carefully reattach the hose to the caliper and nip it up and slacken it off like a standard bleed nipple.
Quite messy but does the trick.
Dan
Re: No brakes
Posted: Tue Jan 31, 2012 5:06 pm
dan_2k_uk wrote:My rears have no bleed nipples.
Dan
That's how I had to do one of my fronts
yup the bleed nipple snapped
Re: No brakes
Posted: Tue Jan 31, 2012 5:12 pm
by dan_2k_uk
its not actually that bad as long as you are prepared for whats going to happen.
Plenty of blue roll, big bucket, brake cleaner/degreaser
get the disc and pads well out of the way!
Re: No brakes
Posted: Wed Feb 01, 2012 9:08 am
by Smalljeep
what sort of bleeder valves are needed for the samurai?
Re: No brakes
Posted: Fri Feb 10, 2012 9:27 pm
by Smalljeep
Thanks to team pink i replaced the old wrecked calliper with a newer one.
But i was bleeding the brakes i released the screw and pressed the pedal down it felt like fluid was going out through the bleeder as normal, but when i tightened it up again the pedal didn't have any feel at all.
To bleed i was using some bleeder pipe connected to the end of a lucozade bottle, i have a gunson air bleed kit but havent used it yet.
