windscreen
Smalljeep
Re: windscreen
Post by Smalljeep » Sat Jul 23, 2011 3:13 am
Newtomud wrote:I saw this post and contacted autoglass..£208 quoted :jawdrop:
thats shocking, i got my old fiat pandas windscreen replaced for £150 a few years back.
would a sheet of perspex do?
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Re: windscreen
Post by ROBBIE » Sat Jul 23, 2011 10:12 am
if its for on road use then no you cant use perspex :er:
Smalljeep
Re: windscreen
Post by Smalljeep » Sat Jul 23, 2011 8:33 pm
Thats £8 more than what i bought my suzuki for.
Smalljeep
Re: windscreen
Post by Smalljeep » Thu Jul 28, 2011 2:08 pm
a quick question
i have a samurai but thats the only one ive ever been in, i dont know what the sj is like. How is its windscreen mounted, can you take off the frame like the samurai or is the roof and all built into the body?
i only see sj's on ebay at the moment.
Re: windscreen
Post by ScottieJ » Thu Jul 28, 2011 2:39 pm
All soft top SJs and Samuarai bodies are exactly the same except for the front grills so you can get a windscreen frame off any soft top!
The glass from a hardtop sj/samurai will also fit a soft top windscreen frame.
Smalljeep
Re: windscreen
Post by Smalljeep » Thu Jul 28, 2011 11:07 pm
but the frame around the window in the hard top its built into the body is it?
am i correct is the samurai the soft top and the sj the hard top, i just assumed all samurais are soft tops since mine says samurai on the sides, although the log book has it down as sj. This confuses me. :S
Re: windscreen
Post by Edweird » Thu Jul 28, 2011 11:20 pm
A Samurai is actually an SJ413 Samurai. It's to do with the track and suspension. Samurai's (and Santana's) have the springs mounted differently to the chassis, and have longer axles and thus a wider track.
Soft top, hard top, metal top and van versions were available with any engine, Samurai or not. The bodywork is completely separate from the chassis and engine, which is what the '413 Samurai' is about, other than the grill and stickers.
Basically, the standard windscreen is the same in all SJs.
Smalljeep
Re: windscreen
Post by Smalljeep » Fri Jul 29, 2011 12:29 am
thanks for that,
that explains the good handling. :P
