Page 2 of 2
Re: local byways greenlanes
Posted: Tue Dec 02, 2008 5:01 pm
by urbanzook
sorry iv bin a way from the club other normal boring stuf.
got my new alto last monday as planned but is the wrong one an there being funny about changeing it.
getting another vit 2 mora gunna use the alto out off that for now as im guna strip it any way for parts
for my missis vit an my sammy.
Posted: Wed Dec 03, 2008 4:21 pm
by Tonka
an dont 4get the parts i could do with b4 you smash it
Posted: Thu Dec 04, 2008 5:47 pm
by urbanzook
sorry and parts for tonks anus, will post
when i see it in day light.
Posted: Fri Dec 12, 2008 9:17 pm
by Tonka
got a lot to do this year bro (urban) need to start soon 3 jeeps need m.o.t or just get running
Posted: Sat Dec 20, 2008 12:46 pm
by urbanzook
hay hay is a live the best is re born running a bit lumpy as she bin sitting for a bit, i hope any way
going up hartford way around 4. to day let me no if ya wanna come an ill meat ya.
Posted: Sun Dec 21, 2008 9:12 am
by urbanzook
ok it did not clear out did not make it as the engine is very under powered.
so i come home before it died. its ok on tick over rev it a bit an it sounds as if its missing
checked all the plugs and all is good. it drives ok as long as your light on the gas.
give it some an it bogs down an holds back an sounds like its missing or losing pressure.
come off an it will pick up slowly and up hill to it struggles.
when i parked it up to do the alto it was fine.
Posted: Sun Dec 21, 2008 1:17 pm
by Tramp
have you thought it might be the fuel filter? also i suppsoe the fuel pump could be on its way out or the breather on the petrol tank may be blocked, it definatly sounds fuel related!
Luke
Posted: Mon Dec 22, 2008 5:42 pm
by urbanzook
new pump dun filters lines ect at the same time. do a job propper an it will last.
the torque of the mota is low soon as you put it under any strain it bogs down.
at times you wood be over fuel in like up hill towing more than one in the car.
Posted: Tue Dec 23, 2008 4:21 pm
by bourneyo
Do you have any leaks in the fuel lines? the pump will pull what ever is easiest, so if you have a small leak it may be opened up under the higher pressure that the pump will be pulling it through so air would enter, but then when you let off the pressure would drop and the leak coule close up again?
abit of a long shot tho
Dan
Posted: Tue Dec 23, 2008 5:30 pm
by urbanzook
nop all the lines are solid changed the lot not long a go.
will check my filters. thinking coil guna change it an check the
earth on the block. and do a psi check on the pistons.
cleen my pcv an carb an see if that dont help or give me
an idea ill change the lump as iv just got the black vit to strip.
