water temperature gauge
Re: water temperature gague
Post by Darrell » Tue Jun 14, 2011 11:42 pm
Have a nasty feeling that gauge set being from America is going to be 1/8 NPT 27 teeth per inch. Not a very common fitting in the UK.
Did the set not come with any adaptors ??
Smalljeep
Post by Smalljeep » Tue Jun 14, 2011 11:51 pm
adaptors:
thats what i have, but can you suggest the sort of adaptor i need.
What about the idea of the pipe where the heater matrix once went?
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Post by twiss » Wed Jun 15, 2011 11:26 am
Here I just thought this might come in handy:
http://stores.ebay.co.uk/McGill-Motorsp ... 34.c0.m322" onclick="window.open(this.href);return false;
Smalljeep
Post by Smalljeep » Wed Jun 15, 2011 11:58 am
ive sent them a question asking if they can make one for my sensor.
my standard gague still likes to tell me my engine is boiling over, is there a resistor i can put in (what value) to tune it down correctly for my engine.
Post by twiss » Wed Jun 15, 2011 12:13 pm
Do you have the vitara sensor installed?
If so, make sure you change it for the samurai/sj sensor
Smalljeep
Post by Smalljeep » Wed Jun 15, 2011 12:19 pm
i still have a vit one in yes, i dont have the sammy one anymore.
Post by twiss » Wed Jun 15, 2011 12:37 pm
That's your problem then... try and get a samurai one... borrow one to test if you can... I think they are only about £5 though
Post by ScottieJ » Wed Jun 15, 2011 1:03 pm
Here is a pic of what someone else has done to fit one of those senders
I'm gonna hazard a guess that the first fitting you measured is 5/8 UNF (hopefully I'm not wrong)
demon tweaks do that size adapter for a water hose.
http://www.demon-tweeks.co.uk/Motorspor ... /1773/1843" onclick="window.open(this.href);return false;
Post by twiss » Wed Jun 15, 2011 1:18 pm
Ahhhh that's a good one!!! You could take the sender housing/lid to pretty much an fab shop and they could do it for cheap!!!
Smalljeep
Re: water temperature gauge
Post by Smalljeep » Wed Jun 15, 2011 11:41 pm
where can i get the standard water sensor?
if it was going i wouldnt need this other gague working, i could put in something more useful like a voltmeter.
