Page 2 of 4
Re: Another Oil related Question
Posted: Tue May 24, 2011 11:07 am
by Smalljeep
when putting it back on does the new gasket need any paste or does it just go on dry
Posted: Fri May 27, 2011 1:48 am
by Smalljeep
the oil leak then, it was just the rocker gasket, all fixed now.
Posted: Fri May 27, 2011 9:14 am
Smalljeep wrote:the oil leak then, it was just the rocker gasket, all fixed now.
Good to hear
kinda useful that I found those O-rings anyway as I need one for mine
Posted: Sat May 28, 2011 11:39 pm
by Smalljeep
theres stiill a bit of a weep of oil
Posted: Sun May 29, 2011 6:48 pm
by Smalljeep
does this include an inlet manifold and fuel pump gasket, can anyone tell from the pics?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _500wt_922" onclick="window.open(this.href);return false;
im going to pull off the inlet manifold and fuel pump, change the pump over to the other one i have, and put the new gaskets on, failing that i dont know.
Its too high for the sump and not the filter, round the dizzy seems clean, the fuel pump is a bit oily though especially round that hole on the side of it.
Posted: Sun May 29, 2011 8:35 pm
There's no oilways around the inlet manifold so you don't need to take that off, you can remove the fuel pump without removing the inlet manifold and no that kit doesn't include a fuel pump gasket. From a main dealer they are £7.17 before vat each and you need 2 if you have the plastic spacer in between the fuel pump and head
Posted: Sun May 29, 2011 11:14 pm
by Smalljeep
about £15 ish then i suppose, ill need to become acquainted to my suzuki dealer then
by Smalljeep
Posted: Mon May 30, 2011 9:57 pm
Unfortunately there are some things that you really have to get from suzuki... speedo cables seem to be another one!
Posted: Tue May 31, 2011 1:12 pm
by Smalljeep
same as peugeot dealers then, although with them its usually the diagnostics machine for electrical problems. Although i bought one there is still some parts only the dealers have.
As for the gearbox oil
i took the lever out and filled it through here, i also loosened that bolt at the side when doing it, is that the place where you are supposed to fill it, its about 4 inches back and up from the drain plug?
