Re: Track Rod Ends
Posted: Sun Jan 31, 2021 9:37 pm
Home of all things Suzuki 4x4
https://suzukiclubuk.co.uk/forum/phpBB3/
https://suzukiclubuk.co.uk/forum/phpBB3/viewtopic.php?t=15280
Samurai axles being wider is almost definitely a must for spoa. Standard sj's didnt struggle at rolling over let alone lifted ones.border wrote: ↑Fri Jan 29, 2021 12:07 amThanks Mate, It gets more complicated with the way my truck is built, if I ever get another I will make sure its all Origional instead of a mixture like this one.ScottieJ wrote: ↑Thu Jan 28, 2021 11:19 pmIt's only the drag link that is a Z bar, a new tie rod can be used with his Z bar.
Only one rod can be changed on the tie, unfortunately its the opposite end to the one you need. You will need to run the Z bar with spoa (or you can convert to a much better high steer set up)border wrote: ↑Thu Jan 28, 2021 7:50 pm
Thanks I thought they just screwed in at each end here http://www.euro4x4parts.com/suzuki_part ... ie_rod_end same as Landrover, thanks for links.
The first link i gave you is just the long half of the tie rod so if you bought that you would need to swap your o/s tie rod onto it (or buy a new one to go with it) if you bought the one in the 2nd link you wouldn't be able to use the drag link as you'd have to run your Z bar but you'd have a normal drag link spare if you ever did swap back to spua like you have previously mentioned.
Also I just remembered you have samurai axles so you would need the longer samurai set up, not the 410 onesThese are samurai width ones, there are cheaper ones on ebay https://www.ebay.co.uk/itm/SUZUKI-SJ413 ... Swa0VZ6z8x
gonna have a good look at the whole front setup tomorrow , will take more pics.
Thanks Mate. Some great Info there , will look in to it.d_r_1989 wrote: ↑Sun Jan 31, 2021 10:45 pmSamurai axles being wider is almost definitely a must for spoa. Standard sj's didnt struggle at rolling over let alone lifted ones.border wrote: ↑Fri Jan 29, 2021 12:07 amThanks Mate, It gets more complicated with the way my truck is built, if I ever get another I will make sure its all Origional instead of a mixture like this one.ScottieJ wrote: ↑Thu Jan 28, 2021 11:19 pm
All the mods yours has are for the better, well once your gearing is sorted it will be.
