Also for the master cylinder have you tried here? Should be Girling for spanish
http://brakeparts.co.uk/#!/shop/SUZUKI/ ... g%20Valves
Help!
Re: Help!
Are the blocks actually different then?Rhinoman wrote:Early 16V Vitara engines used the G16a block, they usually had a Denso injection system rather than the later Mitsubishi system. Over the years they get swapped about though.
I was under the impression that a G16 block was a G16 block - the difference between A and B was piston tops and 16v heads?
I'm no expert, obviously, that's just the impression I got.
