Hello again, grand vitara suspension help?
Rodden87
Re: Hello again, grand vitara suspension help?
Post by Rodden87 » Mon Feb 09, 2015 12:53 pm
Cool, managed to get a sneaky look at a swb minute ago! Looks like there is quite a bit a plastic and inner wing that can go! Not sure I will get such a large tire to work though! So might have to stick with a 31 will have we will see!
W reg jimny, 31" trekker on 15x8 mods, ora 4.5 lift, poly bushed, pro-comp shocks, braided brake lines, sj 410 transfer box with 6.5.1 tg gears, KAP stainless exhaust, custom snorkel and extended arches!
Post by ScottieJ » Mon Feb 09, 2015 12:54 pm
Rodden87 wrote:Cool, managed to get a sneaky look at a swb minute ago! Looks like there is quite a bit a plastic and inner wing that can go! Not sure I will get such a large tire to work though! So might have to stick with a 31 will have we will see!
Angle grinder and welder.....sorted :lol:
Rodden87
Post by Rodden87 » Mon Feb 09, 2015 1:02 pm
Oh yeah choppy choppy, can't wait to get rid of my defender but guess what need to fix it first lol
Post by ScottieJ » Mon Feb 09, 2015 1:22 pm
Rodden87 wrote:Oh yeah choppy choppy, can't wait to get rid of my defender but guess what need to fix it first lol
It's ok we all make bad life choices sometimes :hahaha:
1995 Zuk
Post by 1995 Zuk » Wed Feb 11, 2015 9:33 am
I have a GV1600 SWB, 2" inch suspension lift when I put 245/70/16 tyres on a -30mm off set wheel the tyre just catches (on full lock) the arches. I will trim off the front as plastic, but the rear part i will get someone to do as never welded.
when you lift don't forget the drop brackets and you will deff' need the camber adjust bolts.
2003 GV1600 sport
1995 Vitara SWB
Rodden87
Post by Rodden87 » Wed Feb 11, 2015 2:03 pm
Brilliant thanks for the help! Have you got any pictures of you're zooki's?
Thanks Andy
Rodden87
Post by Rodden87 » Wed Feb 11, 2015 8:27 pm
Hopefully collecting a GV diesel 5dr on Saturday so now the choices start! Much much lift and what tires?
Post by Anton » Wed Feb 11, 2015 9:53 pm
I'd lend you my 31" spare to work out what virtual lift and/or actual lift you require - but I'm a bit too far away.
Got anyone nearby with a 31/33?
Rodden87
Post by Rodden87 » Wed Feb 11, 2015 10:34 pm
That would be a great help if anyone did?
Post by ScottieJ » Thu Feb 12, 2015 12:49 pm
You would be more than welcome to drive up and try some tyres, I have quite a selection of tyre sizes on wheels with various offsets.
However 15" wheels catch on the caliper if it's got any engine other than the 1.6 so it might be a case of fit them as well as we can and cycle the steering and suspension :lol:
