Angie
Post
by Angie » Wed Aug 19, 2009 9:56 am
Think it just the standard for sj 410 970cc santana!!
Henry
- Suzuki Guru
Post
by Henry » Wed Aug 19, 2009 10:00 am
In that case it should have a metalic pipe going from the exhaust manifold to the carb.
Angie
Post
by Angie » Wed Aug 19, 2009 10:01 am
Wouldn't happen to have a pic of that?? !!!!!
Haven't spotted one to compare with.
Henry
- Suzuki Guru
Post
by Henry » Wed Aug 19, 2009 10:14 am
Hold on let me have a look, as i said i rip mine out, and i dont run the standard carb anyway
No sorry havent got a picture.
But your exhaust manifold should have a cover on it, and this will have a port on it to slide the pipe over. This then will go infront of the engine (ontop of the fan) and into the air box.
Henry
Angie
Post
by Angie » Wed Aug 19, 2009 10:21 am
Thankyou, mine has defo got that missing will have another look, take a pic and post it, You wouldn't happen to know what mud guards will fit on mine, vitara maybe???? needed for mot!
Angie
Post
by Angie » Wed Aug 19, 2009 5:26 pm
Thanks x
Henry
- Suzuki Guru
Post
by Henry » Wed Aug 19, 2009 5:33 pm
But i told a little porky
It looks like the pipe goes into the air inlet before the breather.
Havent had chance to look at one as i dont have one..
Angie
Post
by Angie » Wed Aug 19, 2009 8:27 pm
now i am confused!!!!! lol . ok thanks
Henry
- Suzuki Guru
Post
by Henry » Wed Aug 19, 2009 9:03 pm
You will see where the hole is... just shove the pipe there. It has to be beofre the air filter tho. And on thr 410s they are a metal box.
