Vitara central locking weird problem...........
RickUK
Post by RickUK » Wed Nov 26, 2014 6:36 pm
Had a weird problem while dring in my 1998 Vitara this afternoon,the central locking works exactly as it should do and never thus far had any problems with it,but i heard a weird noise a few times while driving and it was the central locking activating as in you could see the buttons on the door going up and down.
It only has done it a few times today but i dont have a clue what the problem could be,has anyone else had this happen ??? or could it be a major problem.
The doors open and close as they should do with the key when you unlock/lock the drivers door and no other symptons,but it was weird that as i was driving along it the buttons started going up and down and you could hear the solonoids clicking as well.
Any suggestion what it could be please,the car is bog standard and does not have any alarm fitted so that would not be a problem,
Deceased.
Current wheels.
Re: Vitara central locking weird problem...........
Post by donkeychomp » Wed Nov 26, 2014 9:48 pm
Poltergeist?
Sure someone will be along with a solution soon...
Post by Darrell » Wed Nov 26, 2014 11:54 pm
Apart from a short or possible loose connections I can't help.
Well only with this..........
Suzuki vitara SV620 central locking circuit..png (128.95 KiB) Viewed 3101 times
