Edweird's Suzuki 410
- Edweird
Re: Edweird's Suzuki 410
Are we not supposed to mention it?
- Tramp
shhhhhh
hi, if your wiring core has oxidised just bare the insulation off to expose enough to join or put terminal on, then simply scrape the wire strands with a stanley blade to remove the oxidisation. then u can solder it. if u crimp or use choc block on oxidised wires u will end up with a very bad joint/connection.
cheers kev.
cheers kev.
Am i rite to believe u dnt really intend to off road this jem? It looks like a spot on little project to get started. Just bn looking at the fotos and its a tidy example. My sj was in similar condition when i got that. That was 10 year ago mind.
Have you been "tinkering" with motors for long? Or is this the first proj?
- Edweird
Yeah, that right Jordi. This is a 'roadie'. Obviously, in winter I might tow people up hills or something, but I'm not going playing in the mud. I want to get it done up to a good condition so I can take it to car shows. I've got my Stepdad, a long time 4x4 owner who's had an SJ many moons ago, along with more Land Rovers than I've had hot dinners and my Dad also has a couple of old (pre-classic he calls them) Vauxhall Belmonts that he's worked on and looked after, so lots of help. I look forward to having my 26 year old Jap-o-wagon next to Dad '89 and '92 Belmonts. Peeing on his parade much?
As for tinkering, this is MY first project, but I've been around cars my whole life, so I know them better than most, but I've still got a lot to learn. I could do most things with clear instructions or someone pointing and explaining, if you know what I mean, but by myself I wouldn't be confident enough to change a head gasket or something so close to vital parts. I'm also not very experienced with a welder, so I'd want some education before I started patching the wings and around the fuel filler.
I need to get a Haynes manual.
Haynes manuals a must. As for welding. Mine is iffy. It holds but wont win any beauty contests. As u may hav seen in the fotos. Its all about practice.
Presuming im home for the weekend im gona knock up a rear bumper and a frame for my stack exhaust to clamp to. Its all about the practice.
Ive dun stuff recently that i wud never hav dun b4 but its going ok. Just wish i had more time.
Im only a bit older than you, but have been round tractors and cars all my life.
Its all one big learning curve, i am all self taught, and have done loads and loads to my sj.
Would have been done a dam sight sooner if i didnt have to do it about 5 times to get it right, and there still more to change!
Keep up the good work fella, im sure you will get the mud bug soon!
I think for those of us who are modifying its not too bad as we make bits to suit. From bumper brackets to body panels.
Luckily for ed hes got a fairly sound body. Ive tried getting body parts and its near impossible.
It will be nice to see one being restored for a change as both of mine are well past resoration. Unless i happen to stumble across two new body shells.
Self taught especially on sj's is the way to be. They're so simple to work on and where i learnt a lot.
Now i've accumulated 11 years of suplus bits it may be time for an ebay auction too.
- Edweird
Thanks for all the advice and encouragment people.
My Haynes manual arrived today, so I'll give that a look through some time soon. Does it have anything on repairing holes in floors, wheelarches and door bottoms?
