In need of a 92 samurai Hand brake cable
Josh-holden
Post by Josh-holden » Wed Nov 05, 2014 6:31 pm
Iv looked for a cable and I carnt seem to find one. I need the nearside one. Truck is a 1992 samurai. Any help would be appreciated
Re: In need of a 92 samurai Hand brake cable
Post by Jordi » Wed Nov 05, 2014 7:51 pm
Which cable is it? There are a few different versions.
Post by Tramp » Wed Nov 05, 2014 8:30 pm
I imagine at '92 it's the 2 cables from the hand brake lever? If so - I couldn't find a nearside cable either, so I bought x2 offside cables and took the clips off one and reversed them to make it work on the nearside
Josh-holden
Post by Josh-holden » Wed Nov 05, 2014 8:55 pm
Yes its the one with 2 cables. I didnt think of that idea, thanks. Where did you get your cables from?
Post by Tramp » Wed Nov 05, 2014 9:35 pm
Just my local motorfactor - they're called bullseye, I can't remember what brand the cable was it was a few years ago, I can remember there were 3 types available, one sort for t-box brake, one sort for the single cable to the back axel, and one cable for the x2 cable type, as I said I just bought x2 of the same and changed the x2 p clips on the cable so they sat right for the other side, other than that the cable is identical!
Josh-holden
Post by Josh-holden » Wed Nov 05, 2014 10:16 pm
Ok, thanks for the info
Post by Darrell » Wed Nov 05, 2014 10:38 pm
Post by twiss » Thu Nov 06, 2014 9:38 am
I think you can also use Jimny hand brake cables for a samurai sport but dont quote me on that!
The ones I got had way too many P-clips on them and in the wrong places
Josh-holden
Post by Josh-holden » Fri Nov 07, 2014 11:54 pm
I rang a motor factor today and they told me that the cable is discontinued. Any ideas where to look for one?
Post by donkeychomp » Sat Nov 08, 2014 12:05 am
Try Pebley Beach Suzuki, failing that maybe Suzuki UK?
