Buying lift springs
Re: Buying lift springs
Post by andyrew » Mon Oct 13, 2014 6:10 pm
What size lift are you looking for? And what's your budget?
Post by ScottieJ » Mon Oct 13, 2014 11:45 pm
How's your fabrication or do you just want a bolt on solution?
Budget doesn't always define how well the suspension does work, my YJs cost me £150 and I fabricated my own conversion.
From left to right.
Dan. Ironman 2" lift, lowered bumpstops
My own YJ set up with around 1" lift, relocated bumpstops.
Jordi. Llama lift springs front and rear, 50mm dropped bumpstops, stock shackles
Twiss. Lllama lifted fronts. Standard rear on lift shackles.
soalsix
Post by soalsix » Sat Oct 25, 2014 11:23 pm
My fab skills are good. Im only looking for a couple inches lift
Post by dan_2k_uk » Sun Oct 26, 2014 12:03 am
If you can fab go for RUF or YJs or a mix of the two.
soalsix
Post by soalsix » Sat Nov 01, 2014 9:17 pm
Ruf it is i think. Like ladaman, ive a pair of navara leafs for the rear. Just need to start fabrication!
