2" body lift
2" body lift
I've already fitted a suspension lift kit but it still does not give me enough tyre clearance so I'm going to fit a 2" body lift anyone fitted one and know were I will find the nuts on the car I know the 2 long blots are under the headlights.
Re: 2" body lift
Try Dave at bits4vits
Re: 2" body lift
2 bolts under the headlights (as you have noted)
2 captive bolts at the rear of the front wheel arches
2 captive bolts at the front of the rear wheel arches
2 captive bolts at the rear chassis crossmember (behind the rear bumper).
The ones at the wheel arches are readily visible if you look underneath from the side of the vehicle.
There are a few forum threads out there with install instructions - google it, but use sidekick or tracker instead of Vitara to capture the US ones.
Re: 2" body lift
Sorry read wrong
Re: 2" body lift
Pico42's explained it well
(Vitara and Grand vitara) , but you know me
Diagram time http://www.offroadingpics.co.uk/apps/ph ... =195366045
Not sure if you have to extend the gear lever and/or steering on a 50mm lift, just something else to consider.
Re: 2" body lift
I really never thought of that , maybe an angle grinder to the wheel arches is a better optionDarrell wrote:Pico42's explained it well(Vitara and Grand vitara) , but you know me
Re: 2" body lift
Yes I do need a extension for the steering column anyone any idea were i can get one
- donkeychomp
Re: 2" body lift
I'd just do a virtual lift rather than lift the body, much easier and that is exactly what I'll be doing very soon!
Re: 2" body lift
PhilD wrote:Yes I do need a extension for the steering column anyone any idea were i can get one
Bits4vits did them (I did have them on our Vitara until we swapped in the power steering), but I can't see them on his website anymore.
Re: 2" body lift
It looks like I'll have to buy a steering column and extend it myself
