muddymesser
Post
by muddymesser » Sat Aug 02, 2014 2:43 pm
what size are sj wheel nuts ? i think its m12x1.25mm pitch but a bit unsure
also a quick tyre question
i know its not legal to have tread sticking out past the arch
but on my sj the side walls just stick out past the arch . . . the sidewalls have tread half way down so where do i stand on this ?
Rhinoman
- Suzuki Guru
Post
by Rhinoman » Sat Aug 02, 2014 5:26 pm
The nuts are M12 x 1.25.
According to the RTA the entire width of the tyre must be covered, not just the tread.
Post
by Jordi » Sat Aug 02, 2014 7:28 pm
I have loads of tread sticking out
- IMG_2739.JPG (2.16 MiB) Viewed 5167 times
Goes through MOT fine
muddymesser
Post
by muddymesser » Sat Aug 02, 2014 8:09 pm
mot is fine with it its just the police and dvla that have problems
Post
by twiss » Sat Aug 02, 2014 9:33 pm
It's normally only if you catch a policeman in a bad mood that they will pull you over for it.
I don't think it's something most of them look for
Around town here though the 5-0 seem to ignore 4x4s and pull the boy racers instead
Post
by donkeychomp » Sat Aug 02, 2014 10:19 pm
Twiss you are a lucky sod! It's the opposite here and mine stick out now...need some fat arches, and even fatter with wheel spacers!
Jay18
- SCUK is my life
Post
by Jay18 » Sat Aug 02, 2014 10:28 pm
Yup m12 x 1.25, should look awesome with the new nuts
And wheels need to go BLAAACK!
My 31's I had on the SJ stuck out a little bit, but the treads were covered, never got pulled once, but I did get some dodgey looks from the coppers a few times and did get followed for a bit by some but never pulled...
