- stevepsj413
That's not the valve on top of the inlet manifold that I don't know the name of?
Your right, thats not the valve on the top of the inlet manifold, keep guessing!
- Tramp
4wd switch on the transfer box?
it's definitely a switch, i don't think it's the 4wd one, as that has only one wire on it, and it looks like the pic has two, so I would think it's the switch on the gearbox, which I think is for the reverse light?
- stevepsj413
Thats it, its the reverse switch on the gearbox, your turn kiwizook!
- DSC_0017.jpg (439.17 KiB) Viewed 6300 times
pic is a little grainy, because it's dark outside, see if you can guess it though
- Tramp
Is it the filler point on the steering box?
good guess tramp, your turn!
Is it a steering column?
Edit: I know its a steering column... steering wheel end
