head gasket SJ413... how easy???
Russ24
Post by Russ24 » Fri Feb 26, 2010 8:47 pm
hello.
i have a rather tired SJ413 and believe the head gasket has gone.
very down on power and alot of White smoke from exhaust.
another reason why its down on power is i submerged the engine bay... aperently water got into the 'bellhousing' but it stayed running the entire time it was submerged.
i have the head gasket set and i was woundering how easy it would be to do myself.
To give you an idea of my mechanical capabilities, my skills stretch to simple maintence on my motorbikes to once replacing a cam cover and shims on an old suzuki bike.
not sure what specialist tools i will need. and Reliable information source to referre to.
apologies again as this is my First post.
thanks for any help info.
:russ:
chan
Re: head gasket SJ413... how easy???
Post by chan » Fri Feb 26, 2010 11:54 pm
welcome to the forum mate!
changing the head gasket on an sj is dead easy.
have you got a haynes manual for your car?
if not heres an online one. dont thank me thank scottiej410 for posting the link :P
http://www.4x4.in.th/manual_sj413/
more people will be able to tell you the dos and donts!
cheers
Russ24
Post by Russ24 » Sat Feb 27, 2010 3:39 pm
i have indeed.
HOWEVER i had a quick look and through process of elimination have noticed that i have fooked the clutch also....
and considering i bought it cheap it suddenly got very expesnive..... short answaer... i think my anus is dead.
but i have a plan. i had previously brought ANOTHER SJ and its still floating about.... guy is getting rid off it and has taken a fancy to my cheap runner ( r reg polo) for his missus.. i think i swap with happen, thus leaving me with a standard ROAD WORTHY sj and an off road dead one.....
im selling a head gasket set :p
and will prolly break it for spares. will keep you informed.
thanks for your comment.
:russ:
chan
Post by chan » Sat Feb 27, 2010 7:25 pm
ill take a window winder handle off it please. how much posted?
Russ24
Post by Russ24 » Mon Mar 01, 2010 8:32 pm
there was only one on it!
i havent created an inventory yet of parts.
but i have just aquired another SJ... hopefully i one working from two piles.
like i said, will keep you posted.
:russ:
