Kawazonkey
Re: Kawazonkey
Post by donkeychomp » Thu Apr 17, 2014 10:04 pm
Forks and swingarm off...got the frame and engine on the work bench ready to take the lump out. I've decided just to spray the frame instead of polishing it. I'd be there for months trying to do that!
Re: Kawazonkey
Post by donkeychomp » Sat Apr 19, 2014 10:14 pm
Engine out! Time to get sanding....
Re: Kawazonkey
Post by donkeychomp » Mon May 12, 2014 10:25 pm
Few bits cleaned up and restored...I'm very happy with the generator cover, had to spray it black then VERY carefully sand down the ZXR bit so it was alloy. Then it got lacquered!
Re: Kawazonkey
Post by dan_2k_uk » Mon May 12, 2014 11:17 pm
Tidy.
Re: Kawazonkey
Post by donkeychomp » Mon May 12, 2014 11:41 pm
Yep, she's slowly getting there. Paying jobs keep on turning up and I can't afford to turn them down at the moment!
Re: Kawazonkey
Post by donkeychomp » Mon May 26, 2014 11:44 pm
Engine is all done and ready to go back in the frame, I hope to have that done by tomorrow.
When I whipped the rocker box off I was amazed at the condition inside. Cam chain, valves etc as new. Then again it has only done 12k, but considering the state of the oil that was in it...
Got a load of parts painted, still more to do!
Re: Kawazonkey
Post by donkeychomp » Thu May 29, 2014 10:11 pm
Frame is done! So is the rear brake cylinder, new pads...£7.95 for the set and a free balaclava lol.
Re: Kawazonkey
Post by donkeychomp » Thu Jun 05, 2014 10:32 pm
Rear subframe nearly done and I've started on the swingarm. I've found using fine grain sanding discs on my corded drill work a treat. Front calipers have been taken apart and the pads are like new so another £ saving! Need to get the forks over to a mate to do the seals then I'll have the chassis all back together. Bodywork next.
(the Alfa sticker is from the original Kawasaki garage where the bike was from...Japan somewhere. Tried to peel it off but it wouldn't budge, shame, I would have like to have kept it!)
Re: Kawazonkey
Post by donkeychomp » Sun Jun 08, 2014 10:01 pm
The subframe is on along with the pillion footrests and the exhaust hanger.
Might go for a funky zorst, either twin pipes exiting above the rear tyre (Ducati 916 style) or twin pipes side by side but using the original hanger...having a think.
Re: Kawazonkey
Post by donkeychomp » Fri Jun 13, 2014 10:36 pm
Swingarm is on!
Is anyone reading this thread? :hahaha:
