gangsta lean
- ektoz
gangsta lean
Hello mates!
i started to have a good amount of lean on the drivers side an its driving me nuts!
i was thinking to jack it up and leave it for a couple of weeks !?
any idea hou to fix it??
Re: gangsta lean
Swap the springs over. It will lean to the passenger side for a bit but then probably balance out.
Re: gangsta lean
Gangsta lean drives me mad . I thought i'd solved it when i put the YJ's on but its started to do it again .
As Dan says just have to swop the springs over.
Re: gangsta lean
Very common problem
Few options are
- become a gangster
- swap springs over
- marry a fat bird
- when not in use leave on axles stands with drivers side wheels hanging
- drive only on roads with lots of camber.
Some are more practical than others.
Financial expense of being gangsta' should be considered first.
Few options are
- become a gangster
- swap springs over
- marry a fat bird
Re: gangsta lean
Re: gangsta lean
Go find a roundabout and drive round and round it as fast as you can
- ektoz
Re: gangsta lean
i will retension the front and rear driver side leafs i think is the best opion, by the way they are
CJ leafs.
CJ leafs.
- Cyprus Geoff
- Can I have a tow
Re: gangsta lean
Gangsta's need machine gunning!!!
- firingTHUMBS.jpg (48.48 KiB) Viewed 8720 times
- muddymesser
Re: gangsta lean
i just jacked up the low side over night usually and its fine for afew weeks
or carry a bag of cement/toolbox on the passenger seat
- dazerede
Re: gangsta lean
Mine is leaning to the driver side even with out me in it so I took the rear springs off and noticed the more curved spring was already on the driver side but people say when driving down the road that it is leaning to the driver side quite a bit
Plus my rear springs should be 1" higher than standard but they have gone to standard hieght naw and the truck is leaning back aswell lol
- image.jpg (1.63 MiB) Viewed 8686 times
4” calmini lift kit
4” calmini lift kit
