Hi,
On saturday i will be collecting a Grand Vitara,54 plate.5 door.
I have noticed that it only has one key remote 2 button.
Can you advise how to programme another remote into the system so the central locking will work on the second key remote.
I assume it would be in the owners manual but there is no manual.
I have managed to find a second remote & key case which matches the original and i have cut the chip out of the spare non remote key.
Once programmed i will then have 2 key remotes.
Many thanks.
Grand Vitara key remote
Grand Vitara,54 plate,2000cc,Manual,5 Door,Air Con,4WD.
Re: Grand Vitara key remote
The workshop manual says
If you can follow that without making a balls up
Thanks,that looks a right mess.
Does this seem a little more sensible to read ??
Probably not
Probably not
- in english.png (30.47 KiB) Viewed 5370 times
Sounds much better.
Do i then also need to do this to the original working key or just the second key.
Just the second key I would assume.
Never had to do this myself, so not sure to be honest.
Just read that, and I was expecting to see "Standing on your head, select..." at some point.
Programmed the 2 keys as advised above and now working fine.
