Forum
Re: Forum
Once again, Thanks so much, feel real welcome !! Hope to put a pic up soon and if anyone does have any info for me at any time brill. One question, when i start fumpa from cold - ok, when warm, have to lift bonnet, connect brown and yellow wire from coil to brown and yellow wire from loom, turn engine over until it tries but won't run, disconnect wire start her again - runs no probs ?
Re: Forum
HELPPPP ! Could anyone tell me what the brown and yellow wire going to the coil is for on my zuki santana ? Bugger won't start till i connect it and then dissconect it when she's warm ?? fine when she's cold tho ?? Please help me if you can, Ta
Re: Forum
Try replacing your coil... those wires connect the coil to the distributor so one of them is probably at fault
Is it a 1.3 or a 1.0???
Also please don't post the same thing over and over in different places
Re: Forum
How to check your ignition coil:
- coilcheck.jpg (92.94 KiB) Viewed 5940 times
- dominic
- Can I have a tow
Re: Forum
Nice one.
We will all try and help and give any advice.
As im not in you neck of the woods, I cant help on garages.
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
Re: Forum
This is how the coil should be wired up.
Can you post a photo of your wiring please?
Re: Forum
Will do asap. Seems to be a green wire to +, a lead going to nothing (brown and yellow) which, when she won't start i connect to the one coming from the loom and she will fire but not run, disconnect and off she goes ??
Seems to be tho, if i leave her to cool this also works and she's a little lumpy till i put my foot down so ... fuel ? going to give her a full check over this weekend
