Post by Anton » Fri Feb 28, 2014 2:14 pm
Ah, ok - yes, sorry.
So if you get trailing arms that are matched to your leaf springs (same length from eye to eye as the spring is from rear eye to the edge of the perch) *and* a bam bar, then the compression forces of the spring would be forced down the trailing arm and the bam bar, stopping the spring from being compressed.
You'd have to mount the trailing arms paralell to the springs, on the inside of the chassis.
Theoretically, that won't damage your articulation, especially if you use rose joints rather than bushes.
Post by mike harris » Fri Feb 28, 2014 5:24 pm
Leaf springs compress to much for a trailing arm.
The awnser is what i am going to do. Fear not.
kiwizook
Post by kiwizook » Fri Feb 28, 2014 7:36 pm
Fear not
never fear when mike's near!
I'm looking forward to how this fix is going to work. good luck bud.
Post by mike harris » Wed Mar 05, 2014 8:13 pm
Sat up the end of the garage cast aside :(
Online
Post by ROBBIE » Wed Mar 05, 2014 9:13 pm
Poor dejected little monster
lesward
Post by lesward » Fri Mar 07, 2014 9:24 pm
just read all 74 pages man what a sweet build grats bud
Post by mike harris » Sun Mar 09, 2014 5:34 pm
Right, before I start a new job if I can find one, I am going to make my front springs have military wrap, but backwards. Hopefully stop the springs fucking up any more.
And Tempory cage beefing up, is very much needed. Can't afford a new one yet !!
Mike :)
kiwizook
Post by kiwizook » Sun Mar 09, 2014 6:18 pm
what is military wrap?
Post by mike harris » Sun Mar 09, 2014 6:29 pm
Where the second leaf in the spring pack wraps around the eye of the spring.
Mike :)
kiwizook
Post by kiwizook » Mon Mar 10, 2014 4:30 am
how will you do that? will you have to extend the second leaf to achieve this?
