spare wires
- timwilks13
- SCUK Website Padawan
spare wires
So I have all the wiring done on the front and checking I have the correct wires left for the alternator, the wiring diagram says I should have a white/red, white/yellow and white/black wire, but I have 2 black and whites, a black and green, and a white and red wire. I cant make head nor tail of where they came from and where they should go? I'm assuming 3 of them are for the alternator, but not sure what the left over wire is....
Re: spare wires
If you have gone SU you possibly have the fuel stop solenoid left over.
Re: spare wires
I have wires left over, just taped them off. When I swap the body over I may remove them from the loom.
Re: spare wires
W/Y main alt output
W/R dash warning light from alt
B/W ign switch to alt
B/W ign switch to carb solenoid (I expect Dan is correct)
B/G on the 410 goes from the starter to coil.
Well that's what I recon
- timwilks13
Re: spare wires
That sounds about right cheers man, my only concern then is that I have no white/yellow for main alt out. Just the w/r dash light.
Re: spare wires
Could be different on the 410 loom?
Re: spare wires
The white an yellow wire is quite thick and should have a connector on it, have you left the other half with the ring connector on it attached to your old alternator? It will be there!
- timwilks13
Re: spare wires
Excellent cheer bud, it was on the old alternator, and I couldn't find where it plugs in the loom as it was hiding under the fuel pump!ScottieJ wrote:The white an yellow wire is quite thick and should have a connector on it, have you left the other half with the ring connector on it attached to your old alternator? It will be there!
