Which fog light bulb do I need, 05 Jimny
Hello group, just a quick one. One of my front fog lights has gone out, can anyone advise on what type to order. Its on a 05 1.2L petrol model, I had a look on EBay but there are so many types available.
Any advice appreciated
Kind regards Otto
Kind regards Otto
- turbo-tom
Re: Which fog light bulb do I need, 05 Jimny
Go to your local motor factors with your reg number and they should have one.
Tom
Ford Fiesta ST
Ford Fiesta ST
Thanks Turbo T, I was thinking on ordering x2 yellow units off EBay so could have done with the type really, some are listed as H8 but I don't know if they are compatible, I suppose my local motor factors could advise though.
Thanks again
Thanks again
- Tramp
Take it out and take a photo? It should be obvious what type it is? Usually spot & fog lights are h3's but I don't have a jimny so couldn't say for sure
- donkeychomp
Take it out, take it to motor factors, get 2 (1 spare).
Well the tinternet says
H3 1998-2005
H8 2006 onwards
Both available in yellow.
I would remove one for a look, just to be sure you get the correct ones.
H3 1998-2005
H8 2006 onwards
Removed & took a couple of photo's, are these H3's ?
Kind regards Otto
Kind regards Otto
Just noticed, they are stamped H11, is this what I order?
- Tramp
I would order h11's if you check eBay they look the same.... I've not h11's before and didn't realise all the plastic shrouding was part of the lamp
- turbo-tom
Yep there H11 just remember to get ones with the right angled connector
Tom
Ford Fiesta ST
Ford Fiesta ST
