Dear Group
Can anyone help me please. I would like to add an additional 12V battery to power the extra lights and accessories which I have on my sj413, while the engine is not running, so that the main battery won't be at risk of going flat. There is plenty of room for it in the space on the exhaust manifold side of the engine and I am sure it could be secured alright. How would I wire it up and connect it. I am pretty useless technically so when answering please assume that I am a complete moron.
All help and suggestions gratefully received.
Many thanks
Tony
Adding additional battery to my sj413
Re: Adding additional battery to my sj413
HI TONY AND WELCOME.
TRY THIS LINK IF IT WORKS.
http://www.marcleleisure.co.uk/Sund001/ ... arge01.htm
IT'S WRITEN PRITTY STRAIGHT FORWARD.
TONY
TONY
- liljitjit
it should n
be on the diy section on here or it use to be.
[/color]before you laugh at mine , take a look at your own![/color]
- RickUK
- Can I have a tow
Would i need this option if i use a small winch on the SJ its one of these winches that goes over the towball and i have adapted one of those connectors that you charge up batteries on forklift trucks which i have tested to see if it all works but have never used it to its full pulling power si am not sure if adding the extra battery would help.I fully understand i would have to leave the engine running most of the time while recovering the SJ but would one big battery or 2 smaller one be the better option.
I have to make a decision soon as i have just found out my battery that is on the motoer is on its last legs,so any suggestions would be most welcome.
Rick
Rick
Deceased.
Current wheels.
Current wheels.
- RickUK
- Can I have a tow
As my original battery on the SJ has started to become unreliable i was going to buy a new one, but i have been given a 6 months old one from a shogun diesel its a bloody heavy old thing but i think this will fit in the engine bay but i may have to make another bracket to hold it in safely.
As this is much bigger and more powerful it wont cause any problem with the alternator will it ??? and if i remember correctly the SJ did have problems with the starter as the battery was not really powerful enough but you could buy a harness kit from Ebay that would cure this problem so would the bigger problem sort this out instead ???
Rick
Rick
Deceased.
Current wheels.
Current wheels.
It shouldnt cause any problems with the alternator as all it does is charge the battery, but with a higher ampage battery you may start blowing fuses, so just carry a few spare. when i had a higher output alternator on my sj it kept blowing fuses, the most common fuse to go was the one to the ignition system killing the SJ.RickUK wrote:As my original battery on the SJ has started to become unreliable i was going to buy a new one, but i have been given a 6 months old one from a shogun diesel its a bloody heavy old thing but i think this will fit in the engine bay but i may have to make another bracket to hold it in safely.
Rick
as for the starter motor problem, it wasnt an issue with the battery it was with the wiring, suzuki used a wire that wasnt up to the job and would burn out over time, the harnes you can get from ebay just upgrades the live to the starter to a higher ampage cable, if you do suffer that problem it is cheaper to make your own and quite easy!
Dan
Known as a clicky starter.
All i have done with mine is wire in a heavy duty push button on the dash. This mearly engages the starter. The engine will not fire without the ignition on.
Big batteries are fine, make sure they are secure tho. Last thing you want in a roll is a batter flying about earthing out all over the place.
You really need two batteries if your running a winch,, lights, etc. mines running a heavy duty split charger. i made a battery tray from light duty angle, welded to form a tray, then bolted to bulkhead and inner wing..
Andy.
Andy.
