Can someone please explain what shackle reverse is.
SteveR
Post by SteveR » Fri Dec 13, 2013 7:34 pm
Hi all
Keep on reading about shackle reverse, what is it ? Pics would be great.
just for info only as at the moment intend on keeping standard height everything.
Steve
windsor
Re: Can someone please explain what shackle reverse is.
Post by windsor » Fri Dec 13, 2013 7:46 pm
Basically its putting the fixed shakle one with no movement at the front
And the shakle with forwards and backwards movement at the back
1994 sj 413 sierra
cheker plate door cards
cd players
asin free wheeling hubs
99% rust free
alloys
bukets
some leaks here and there
trotter
Post by trotter » Fri Dec 13, 2013 7:56 pm
The leaf spring set up on the rear of the truck stays the same.
But on the front it moves the shackle from the front of the leaf spring to the rear of the front leaf spring, the theory is it allows to axle to move backwards slightly when encountering bumps in the road therefore eliminating bump steer (I think that's the idea anyway) it usually raises the truck by an inch or 2 as the shackle tower part at the front of the truck is a bit longer than standard shackles.. (See pics in my build thread as that's what's on mine currently)
if in doubt, FLAT OUT!
dazerede
Post by dazerede » Fri Dec 13, 2013 10:54 pm
Here is a few pics mate I have just bought a set of calmini springs with 2" shackel reverse kit I have only fitted the calnini kit to the rear at The momoent
Look at my arch gap :)
4” calmini lift kit :)
SteveR
Post by SteveR » Sun Dec 15, 2013 8:55 am
Thanks guys.
Trotter, nice fabrication, wish I'd learnt to do that.
Dazerede, let us know how different it feels when the front is on compared to original, would like to know if it stops that whoaaaaaa moment when you hit a bump at anything over jogging speed.
Steve
Post by ROBBIE » Sun Dec 15, 2013 9:21 am
SteveR wrote:Thanks guys.
Steve
Nah still get that
Post by dan_2k_uk » Sun Dec 15, 2013 9:38 am
Steve
The best way to minimise that is to have minimal lift and a good steering damper.
dazerede
Post by dazerede » Sun Dec 15, 2013 10:19 am
Steve
Well I don't get that feeling anyway I have to get longer shocks and brake hoses first before I.fit the kit but I might fit the front springs and when I get longer shocks and that I will bolt on the shackles
Rhinoman
Post by Rhinoman » Sun Dec 15, 2013 7:51 pm
I've given this some thought. The stock front springs are flat so when they compress they get shorter so theoretically the axle should move backwards anyway. If you have arched springs then they would get longer which would move the axle forward, in that case shackle reversal makes sense.
Post by turbo-tom » Sun Dec 15, 2013 8:57 pm
Shackle reverse on my truck from the front. ignore the bits of shoddy box section to the out side of the shackle towers.
