Basic wiring
timwilks13
SCUK Website Padawan
Basic wiring
Post by timwilks13 » Fri Dec 13, 2013 1:02 pm
What is the least amount of wiring that needs to be done to start a 413 engine? As in, there are no lights or side repeaters connected, horn, wiper motor, thermometer sender, etc. I cant get my 413 engine running and was wondering what is the minimum wiring required for starting.
All I have is the starter motor, coil and dizzy wired in, and that is all. That should be enough to start an engine surely? (and the battery of course)
Re: Basic wiring
Post by dan_2k_uk » Fri Dec 13, 2013 2:19 pm
That should do it if you don't have a fuel stop solenoid. Which you won't if you have the SU.
Re: Basic wiring
Post by dan_2k_uk » Fri Dec 13, 2013 2:20 pm
It is advisable to wire up the oil pressure switch too so you know there is oil pressure.
timwilks13
Re: Basic wiring
Post by timwilks13 » Fri Dec 13, 2013 2:23 pm
yea got the oil pressure on. just get a horrible relay clicky sound and nothing else, but just had a wee chat with twiss and going to do a starter motor test first and put in a clicky fix. then see where im at.
Re: Basic wiring
Post by twiss » Fri Dec 13, 2013 2:23 pm
i asked tim, the starters clicking, so probably either a dying starter or a shit starter wire
ive advised him on how to test it, and the clicky starter relay fix, it was just easier on facebook :P
Boyes
Re: Basic wiring
Post by Boyes » Fri Dec 13, 2013 2:33 pm
Do you have a good earth? Can cause a clicky or one click starter motor, failing that try another battery.
Re: Basic wiring
Post by twiss » Fri Dec 13, 2013 2:37 pm
yeah if its the main earth lead it tends to click and then all your electrics go off! haha
my truck was doing it last night so had to do a bit of late night rewiring!
timwilks13
Re: Basic wiring
Post by timwilks13 » Fri Dec 13, 2013 2:40 pm
Before she goes back in for an MOT the whole thing is getting re-wired, every wire everywhere will get replaced, was just hoping to get it into a drivable state before tackling that, but if i cant work this out that job might get pulled forward to solve any earthing issues!
Re: Basic wiring
Post by twiss » Fri Dec 13, 2013 2:41 pm
lol id come give you a hand tim but its quite a drive :P
timwilks13
Re: Basic wiring
Post by timwilks13 » Fri Dec 13, 2013 2:48 pm
twiss wrote:lol id come give you a hand tim but its quite a drive :P
what? its only 297 miles one way, ill put the kettle on and see you in 6 hours :P
