Does anyone know where I can one of these ??
Had to do the clutch on my samurai and notice as I took the clutch plate off this bearing was buggered . It has got a vitara 1.6 eight valve in it the engine code is g16a . Any help would be much appreciate . Cheers
Liam
Liam
- image.jpg (2.25 MiB) Viewed 5811 times
- image.jpg (2.38 MiB) Viewed 5811 times
Re: Does anyone know where I can one of these ??
From what I can find it should be a double sealed 10x30x9mm bearing. same as on the sj410.
the code is 6200 2rsr
yes, I was also wondering why that bearing has no seal.ScottieJ wrote:From what I can find it should be a double sealed 10x30x9mm bearing. same as on the sj410.
could be why it's no longer any goodRhinoman wrote:yes, I was also wondering why that bearing has no seal.ScottieJ wrote:From what I can find it should be a double sealed 10x30x9mm bearing. same as on the sj410.
Nice one ! Thanks Scott . Other thing I was meant to ask , was can you run without it ?
I would not run it without one, it supports the gearbox input shaft, plus for a £5 component it's not really worth the risk.Tregembio wrote:Nice one ! Thanks Scott . Other thing I was meant to ask , was can you run without it ?
I had the same problem with mine when i changed the gearbox. Just took the remains of the bearing to my local bearing supplyer and they were able to match it up with one off the shelf.
The question is... where did the other ball bearings get to???
Nowhere, that's all you get
But the cage has gone walkies..
Yeah didn't find the cage , seal or the other ball bearings :/ never mind . Bearing should be here today and all being well she will be back on the road thanks again .
Liam
Liam
