Mike, have you sourced bearings for the diff? I know Scott was after some for a diff rebuild, and I could obtain them considerably cheaper than anywhere else through a company at work if you want to let me know the bearing numbers.
Otherwise it's sounding good just lacking pictures!
- mike harris
- SCUK is my life
It doesn't need bearings as the carrier just needs to come out.
Good to know though, sure il need some in the future.
Mike
Mike
- mike harris
- SCUK is my life
Progress !!
- image.jpg (661.87 KiB) Viewed 5701 times
- image.jpg (716.73 KiB) Viewed 5701 times
- image.jpg (794.34 KiB) Viewed 5701 times
- image.jpg (697.33 KiB) Viewed 5701 times
- image.jpg (742.22 KiB) Viewed 5701 times
- mike harris
- SCUK is my life
I am pleased with this, still may well take the rear back out and do more trussing !!
Honesty if this bends I am going portal.
Mike
Mike
- Edweird
That looks monstrous! It's got a Mad Max quality about it.
The
looks like it's hampering the shorter truss a lot though.
The
- dazerede
Looks good
umm that looks inposible to bend tbh
4” calmini lift kit
4” calmini lift kit
- mike harris
- SCUK is my life
That will be fine !! Truss me !! Haha
Thing is the other sides solid, and there made of thick steel, the only way it will bend is if the welds break. Diff housing breaks up maybe or the knuckles them selves break.
- suzukisteve
- Suzuki Guru
mike if you bend this, A: I want a video of the crazy shit you were doing at the time, and B: you should receive medal for it!
pickle power!
- mike harris
- SCUK is my life
Haha !! Yeh lets hope not
With a bit of luck il get a diff today and then I can build it with the new shafts and ain't it
