kiwizook
- SCUK Addict
Post
by kiwizook » Wed Oct 16, 2013 8:30 am
got all these bits today
new transfer box mounts, transfer case lever boot, and new crank shaft bolt.
- all the new bits and bobs
- Pic_1016_222.jpg (273.29 KiB) Viewed 5894 times
also had a look at the exhaust, and found this
- one side...
- Pic_1016_224.jpg (293.17 KiB) Viewed 5894 times
- ... and the other
- Pic_1016_225.jpg (241.46 KiB) Viewed 5894 times
I'll try to find a new splitter that fits, and weld in a new splitter. one more thing to add to the list
kiwizook
- SCUK Addict
Post
by kiwizook » Fri Oct 18, 2013 5:02 am
so started with this
- not so good
- Pic_1016_224.jpg (293.17 KiB) Viewed 5870 times
cut the broken bit out
- cut the nastiness out
- Pic_1017_227.jpg (417.49 KiB) Viewed 5870 times
go these
- shiny bits
- Pic_1017_228.jpg (371.79 KiB) Viewed 5870 times
and managed to do this
- and made this :D
- Pic_1017_229.jpg (275.91 KiB) Viewed 5870 times
- Pic_1017_230.jpg (311.11 KiB) Viewed 5870 times
the welder wasn't going well, but after I had it set up right, I started over again, and I'm quite happy with it now. just have to join the two halves under the wagon now, and weld them together
dazerede
Post
by dazerede » Fri Oct 18, 2013 7:19 am
That looks better all u have to do naw is fit the cherry bomb on the end and that will be sweet
4” calmini lift kit
kiwizook
- SCUK Addict
Post
by kiwizook » Fri Oct 18, 2013 10:17 am
I'll be keeping the standard muffler on it for now, as it has to go through a re-vinning process, and they might not like a cherry bomb on there. I will eventually put a straight through with a cherry bomb on it though, more noise than power
Post
by turbo-tom » Fri Oct 18, 2013 10:28 pm
kiwizook wrote:more noise than power
More noise then you can shake a stick at.i like
Tom
Ford Fiesta ST
dazerede
Post
by dazerede » Fri Oct 18, 2013 11:30 pm
Haha I like that more noise than power
4” calmini lift kit
kiwizook
- SCUK Addict
Post
by kiwizook » Fri Oct 25, 2013 8:10 am
alright then. got monday off as it's labour weekend. I've just set the welder up with 0.6mm wire, got plenty of gas, weld through primer and sheetmetal. you all know what that means
Post
by Jordi » Fri Oct 25, 2013 8:20 am
Your coming round mine to repair all my bodywork?
kiwizook
- SCUK Addict
Post
by kiwizook » Fri Oct 25, 2013 9:13 am
unfortunately that won't work in a single day, I could do if I had more days off
Post
by Jordi » Fri Oct 25, 2013 9:28 am
Guess you must be plating, patching and welding yours then.
