Boring post but help needed on fluids please?.
b3n16
Post by b3n16 » Mon Oct 07, 2013 6:46 pm
I have been looking for my old manual but seem to have lost it in my recent move :er: Anyways I was thinking about dropping all the oils out of the vitara and replacing, however I don't know what with. I have a j reg suzuki 1.6 and this is all I know. Can I please have help identifying what model this is and also what oils to use and rough capacity?. Oh also it has about 110'000
Re: Boring post but help needed on fluids please?
Post by Jordi » Mon Oct 07, 2013 7:06 pm
http://forum.suzukiclubuk.co.uk/vi ... =36&t=8399
Engine oil wise i just use 10w40. No need for castrol, but avoid the cheapest of the cheap.
b3n16
Re: Boring post but help needed on fluids please?.
Post by b3n16 » Mon Oct 07, 2013 7:40 pm
Thank you very much. Any idea on capacity's please?. Also I knew about the gearbox oil because I read about it on that page already but could you explain the reason for the urgency of this type of oil. Thanks again and sorry for keep asking questions
Post by Jordi » Mon Oct 07, 2013 8:10 pm
No idea. I think its all about the type / grade of metal used in the gears and bearings.
Thats the only info i really know of.
Post by Darrell » Mon Oct 07, 2013 10:15 pm
b3n16 wrote:Thank you very much. Any idea on capacity's please?. Also I knew about the gearbox oil because I read about it on that page already but could you explain the reason for the urgency of this type of oil. Thanks again and sorry for keep asking questions
Which capacity are you after, the link showed transmission and transfer..
GL5 oil has additives that can be corrosive on yellow metals (syncro rings),
GL4 doesn't :thumbup:
Post by Darrell » Mon Oct 07, 2013 10:18 pm
more info
Vitara diff oil.jpg (127.71 KiB) Viewed 4716 times
