More problems , to HIGH ?
Re: More problems , to HIGH ?
Post by Edweird » Fri Oct 04, 2013 8:34 pm
A Rockwatt manfold and an SU carb would save you a lot of height, and you'll get a much better carb out of that deal.
lukey4x4
Post by lukey4x4 » Fri Oct 04, 2013 8:43 pm
orrighty how much r we talkin here edweird , alot of over time lol
Post by Jordi » Fri Oct 04, 2013 8:57 pm
I'm not sure. It may be because you are keeping it SPI that it is so tall. See what some more of the lads reckon.
Post by dan_2k_uk » Fri Oct 04, 2013 11:00 pm
Spi is the problem. Like already said you need to go Hif44 on rockwatt manifold and chop the cross bracing off the back of the bonnet to get close. Even with that setup Scottie still has a hole drilled in his bonnet for the top of the SU dash pot.
Sammi bonnet and rockwatt manifold would deffo solve it.
Bout £120 for the manifold mod IIRC and whatever you can find a carb for.
Christoff
Post by Christoff » Fri Oct 04, 2013 11:10 pm
I have a hole in my bonnet for this reason. It's ugly. :(
Post by Jordi » Fri Oct 04, 2013 11:12 pm
dan_2k_uk wrote:Spi is the problem. Like already said you need to go Hif44 on rockwatt manifold and chop the cross bracing off the back of the bonnet to get close. Even with that setup Scottie still has a hole drilled in his bonnet for the top of the SU dash pot.
Also need an electric fuel pump if you swap to a carb.
Rhinoman
Post by Rhinoman » Fri Oct 04, 2013 11:47 pm
What diameter is the top of the throttle body? you may be able to swap to a Samurai injection air filter setup, that doesn't go over the top of the engine as its mounted on the intake side.
Rhinoman
Post by Rhinoman » Fri Oct 04, 2013 11:52 pm
lukey4x4
Post by lukey4x4 » Sun Oct 06, 2013 8:42 pm
Thanks people for now think al take the bracket off the engine mount and drill the hole in , and cut a scoop out the bonnet will lower it abiti low on funds at the min soo will have to do thank for the help
