More problems , to HIGH ?
lukey4x4
Post by lukey4x4 » Fri Oct 04, 2013 6:58 pm
Had my engine in sittin on the mounts what i thort was it and ready for welding , so to nyt i put my bonnet on just to see if it was ok and it wasnt , thers a inch to take off the strengther that goes across the inside of bonnet but still no where near closing , what to do
lukey4x4
Re: More problems , to HIGH ?
Post by lukey4x4 » Fri Oct 04, 2013 7:00 pm
Post by Edweird » Fri Oct 04, 2013 7:15 pm
Power bulge.
Or get a Rockwatt manifold and an SU HIF44 carburettor.
ferris
Post by ferris » Fri Oct 04, 2013 7:17 pm
That is quite a gap. A samurai bonnet will give you a bit more room but probably still not enough. Can you modify the air intake so it doesnt go accross the top of the engine?
Or a body lift would probably sort it.
Post by Jordi » Fri Oct 04, 2013 7:18 pm
Have you got pictures of how you have the mounts set up?
lukey4x4
Post by lukey4x4 » Fri Oct 04, 2013 7:22 pm
anoo it is a big gap a Sammy bonnet will not fill that lol a was thinking of a scoop but wanted to see if it could sit any lower , yer jordi giz a tick n al put them o,,n thanks
lukey4x4
Post by lukey4x4 » Fri Oct 04, 2013 7:26 pm
Drivers side
lukey4x4
Post by lukey4x4 » Fri Oct 04, 2013 7:27 pm
Passenger
Post by Jordi » Fri Oct 04, 2013 7:32 pm
Drivers side needs the spreader plate removing and the box bit drilling so the rubber mount bolts direct to it.
That'll drop it a bit.
lukey4x4
Post by lukey4x4 » Fri Oct 04, 2013 7:56 pm
thanks jordi u think that's all I can do , n al just have to cut a scoop out ?
